Well, it's time to get things in order, it's been down in high 30's to low 40's the last couple nights. This year I plan on using the small fan set up I purchased from Northern Tools with the small heater that attaches to circulate the heat better in the box. I have a electrical/mechanical friend that is going to rig me up a thermostat for that. I run two separate heaters from 2 separate circuits but last year I had 2 very close calls with a breaker tripping on one heater and woke up to some lines almost froze and solved it by running a salamandor for 3-4 hours to thaw them out.
Does anyone have info leading to the temperature monitoring devised that DOES HAVE an alarm built in? I used one from WalMart last year which worked fine but did not have the alarms (hince my almost 2 freeze-ups).
Most of the time I have jobs every night except Friday and Saturday nights so freeze ups are not a huge concern because the box is pretty warm when I get back to the shop, however, when Friday afternoon comes along the 2-3 day period that the truck sets idol is the time that I have the problems when the fresh water tank begins to loose it's warmth and the water gets down to below 50 or so. Sometimes I will just start the truck up and drive it around Lexington once to heat up the fresh water tank and things are better with that.
I am going to have at least one dedicated circuit run for the heaters (maybe two) if I can get my brother in law back here before December.
Sorry I know I am being long winded, just need a link to heat monitors with alarms.
