Captain Morgan
I've got a 2 yr old plug in Multi Sprayer. I noticed on my cleaning job yesterday it was leaking a bit out the bottom after letting off the trigger. I've looked at the lines, fittings, clamps, they are all fine. The pump is leaking from the bottom. Some background info:
In December, it frove up a bit in my van during the day while cleaning but it thawed inside the customer's house, applied protector and used it afterwards with no problems. A couple weeks ago was the last time I used it to apply some Urine Stain Remover. I immediately remembered I not flushing the system after use and it sat like that for a couple weeks until yesterday.
I don't know if the slight freeze damage was worse than I thought and has finally come home to roost, if it's from letting the USR sit for so long or a combination of both.
My question to anyone with experience with this system or the Flojet pumps.. Should I replace the entire pump to the tune of $130 or are the replacement pump kits reliable, easily replaced and the more sensible way to go. Doesn't look to difficult but looks could be deceiving..
Thanks,
Thanks,
