mutli sprayer jets
vincent
Vincent Sapp
Does anyone use a bigger jet other than the one that comes with the ms to get more flow when applying prespray?
If so, what size?
Vin, you live in Cooterville....er..Heartland USA, there's GOT to be a farm supply store some where not too far from you.
Tractor Central Supply (TCS) stocks teejets here
They'll all be 80 degree angle cause that's what com ag sprayers use.
They'll have them in every flow rate.
Jr...take out that damn check valve out of the end of that wand. Then it will be all better.
Chad
Vincent;
MultiSprayers use both V-Jets and T-Jets.
V-Jets are more difficult to find.
Our customers use many different sizes jets on them, depending on the application.
A 8006 is a good choice for prespray if you have good spray wand technique.
Johnny
Johnny
8006 or 11006 for carpet prespray. Stock brass lance valve started leaking big time Thurs. Replaced with Hydroforce-type trigger. Nice to not need to hold brass valve with a rag when applying hot prespray.
I never understood guys who MIST the carpet with Pre-Spray, get it down, and get it down fast, time is money and chemistry is a labor saving device.
I'd have a minimum of a 9506 if I was using it with a TM HWE.
Time is money, and clogs are for the birds.
FastEddie
Like Chad said, take that restricting check valve out, it will perform better and cause lets stress on the pump. I put a #4 jet on it and it puts down pre-spray much better. I put on a fancy circle valve on the end so there are no drips. I hate drips.
