B&BGaryC
- Joined
- Apr 6, 2007
- Messages
- 4,667
- Name
- B&BGaryC
You make it, I'll buy it.
A hydroforce system that includes the straw and the metering tip in each jug, instead of on the sprayer. You simply click and lock the jug firmly in place with one fluid motion. You don't have to bother with the Revolution which most cleaners won't go near, and you can keep different chems with different dilutions in their original concentrations, and freely switch jugs in seconds, without changing tips.
The second, is a flood extraction tool for basements and crawl spaces that are flooded with several feet of water.
If you are working with a truck mounted flood extractor with a good APO, I think this tool would be valuable. It would be similar in design to a water claw, except it would be on a "raft". It would have floatation devises around the edges, that kept the tool just barely above the surface of the water, so it could breath and still remove tons of water. Because it floats it would stay the same height off of the surface of the water until it's all drained. I am wondering if you would have to secure the hose to the ceiling to keep it from tipping, or if you could add weight to it to be able to keep it upright. (And adjust the buoyancy accordingly.
Lemme know what you think.
And on second thought, if you use my ideas, you better send me one for free.
