Jamesh921
...and some questions.
I'm trying to get the hang of encapping so today I encapped the living room in an apartment and then I encapped 3 motel rooms.
Tools - 175 rpm and pump up sprayer
Chemical - Harvard's Bone Dry Encapsulation Chem
After encapping the living room in the apt, I put a fan on it to dry, did several repairs, restretched the bedroom, hall and bath and then started cleaning in the back of the apt. By the time I got to the living room it was definately completely dry.
The area looked "much" improved, but some of the spills could still be seen (lighty, but still visible). I used my TM to vac it and it looked a little better. I thought, "What the heck? Extract it." So, I did -----and it came out MUCH better. Spills dissappeared and carpet was much brighter.
The carpet was a medium brown colored, cut-pile nylon.
The motel rooms were brown with a darker brown, square-patterned cut-pile nylon. They came out fine, but I had to go over the spills ALOT to get them to fade out.
So my questions are;
1) Is it necessary to go over and over spills (probably soda spills) or do you just zip over them like the rest of the carpet and let the encap do its job?
1a) Do you apply more chem on spots or spray everything evenly?
2) Do you apply the encap chem at the same sf rate that you do say, thru your hydroforce? Or, do you apply it lighter than that?
3) I used a bonnet to agitate. Should you flip/rinse/change the bonnet regularly or just keep using the same one for the entire job?
What say you encapping pros?
James
James
