Okay I came up with this idea, took it to Tim and we put on together. It is a very simple add on takes about ten minutes to do, what it does is boosts the incoming water to help out hx system.
It needs NO extra fuel, no crazy plumbing to get it to work.
Here is a pic of it on my TM. If you look all I did was take the QD off TM put it on booster then took hose from booster to TM.
The video is me cleaning and showing my ATW temps, this was today and I was out 100' I am going to try my 3/8 hose tomorrow and see if heat is even better as the hose today was skinny so it looses heat faster.
The video is a little long 13 minutes, but I would like some feed back on what you all think of the temps. If you skip the first minute I start to show heat results from there on.
Thanks Tom
Thanks Tom
