Goomer said:Congrats.
When you get a chance, open her up to get to the lower compartment that contains the vacs and pumps. You will see 2 clear hoses connecting to the inside of the rear fill connector and pump out connector. They should each have 2 hose clamps on them. My clamps were loose from the factory and slipped off during one of my first jobs. I have heard of this happening to some others. I put a thin coat of flexible GOOP on the barbs and tightened them down securely. Something you might want to check.
kevinj61 said:thanks goomer i'll do that, have you heard of anyone taking out the pressure sensor switch or anything like that onthe mytee hot turbo heater so it won't leak if your psi is too high
kevinj61 said:how do you remove it, is it hard and is it safe for the unit itself because i would love to do it please help!!
kevinj61 said:ok i'll call nathan at mytee and thank you very much john, hey and while were at it have you ever cleaned carpets using the encapsulation method and can it be done using a 175 rotary which i already have one of those and don't want to buy another machine if i don't have to but all i have is the carpet brush for it, will that work or do i need to buy some other type of wheel or brush for it again thanks for you help and info
