Mar 29, 2015 #1 J J Brown Member Joined Mar 27, 2015 Messages 128 Location Georgia Name Jeff Brown I need the spring that is inside the knob on the pressure adjustment, anyone know where I can get one?
Mar 29, 2015 #2 dgardner Moderator Joined Apr 7, 2008 Messages 5,109 Location Phoenix, AZ Name Dan Gardner Sounds like you need a part for the pressure regulator, not the pump itself. Is there a number on the regulator - like MV520? Can you post a pic?
Mar 29, 2015 #3 GeneMiller Member Joined Mar 24, 2009 Messages 3,541 Location Boca Raton Name gene miller Doesn't that spring just hold the adjustment in place. Go to your supplier he probably has a pile of old pumps. Pull one off. Gene
Mar 29, 2015 #4 J J Brown Member Joined Mar 27, 2015 Messages 128 Location Georgia Name Jeff Brown Yes, sorry it's the pressure regulator, can't find any numbers on it, I'll see about getting a pic. Also I'll check around for someone with old parts. Thanks guys
Mar 30, 2015 #5 Desk Jockey Member Joined Oct 9, 2006 Messages 64,833 Location A planet far far away Name Rico Suave Repair kits are available for most regulators. New spring, o-rings, some even come with the piston. http://www.jondon.com/valve-repair-kit-pressure-regulator.html Reactions: dgardner
