curt johnson
I have a Blueline Bluewave. It has approx. 3000 hours on it. When I start at first job in the AM she starts up right away. After it's warmed up and running for a while on a job if I shut it down or when I go to the next job is where the problem is. If the machine shuts down while hot when I turn key to refire it it won't turn over. The fan starts and it "clicks" but won't turn over at all. I have to turn the key about 10 to 20 times and then it will normally fire right up like normal.
I'm afraid I'm going to wear out the ignition or something, or drain the battery because of this. Any idea what would cause this?
