The jets on my wand are dripping, even when the extractor is not on. I took the jets off and cleaned the screens, but they still drip. Any suggestions?
the o-rings on the K or P valve (the wand trigger valve) are worn out!....We replace those o rings every month or two. Go to a specialty o ring/gasket shop and bring in a new o ring and let them size it up. Make sure you tell them that soap and hot water gets used with your application to ensure the proper o ring material. I think the material and or brand of o ring needed it VITON. I am 100 percent sure that this is your problem.
