Art Kelley
This came in the mail yesterday: 15 gallon CFX. It is 10" taller than my old 5 gallon CFX. This should alleviate the problem of the shallow 5 gallon tank blowing the occasional foam out the exhaust (and onto the customer's walls if using indoors), and also allow the cleaning of a few rooms without the need to dump. The motor unit is the same, two 3 stage vacs and a diaphragm waste water pumpout, the extension tube that operates the on/off pump switch is longer as is the siphon draw tube.
They weigh about the same, 50-55 lbs, the CFX 15 has a dump valve. The standard CFX is 24 inches tall and the CFX 15 is 34 inches tall. The base seems to be the same width and length,14x18"
