MB Auctions
- Joined
- Sep 15, 2014
- Messages
- 92
Description:
.3400 Series 200°F / 93°C, High-Temperature and Intermittent Run-Dry Plunger Pumps from Cat Pumps
The “.3400” series plunger pumps starts with the same high pressure seal/V-Packing modification as the “.3000” series” and changes the
low pressure seal to a special PTFE high temperature material. Ordering this configuration requires adding “.3400” to the base model.
The special blend seal materials allow the pump to run dry intermittently without damaging the seals.
Bid Now at CleaningClassifieds.com
** You must create a CleaningClassifieds.com account in order to bid on items. Your Mikey's Board credentials will not work. Click the following link to create your account: http://cleaningclassifieds.com/register.php **
