New Devastator Inline Lint Filter
MB Auctions
We have a fully custom option Devastato Inline Filter up for auction
Your choice of Vacuum port set up; 2' to 2', 2' to 2.5' or any four to the door combinations
$400 plus retail w/ FREE shipping to the lower 48
Stainless Steel version only.
The Devastator is an inline filter that captures such a large amount of debris before it enters the tank that it virtually eliminates having to clean your waste tank out. In fact cleaning out your blower intake filter 3 times a year should be sufficient, and adding an inexpensive microban in the waste tank will help keep the odors away
This filter is meant for the real power of a truck mount not only because of its debri catching capacity, but the way the bags are designed. They are made specifically to help your truck mount keep flowing air for much longer with uninterupted work times compared to other inline filters on the market.
No more stop and go cleaning, you can pull up to a job set up your hose run with the Devastator filter (on most jobs) and finish with almost the same airflow you started with. giving you the longer uniterupted work times
The Devastator also has recessed ports allowing it to be stood up on its end making it easier to rinse it down between jobs and also taking up less space in your cleaning vehicle.
The Devastator ports are universal, meaning whatever you are running cuffs etc. will connect directly to the filter ports with no other attachments or starter pieces needed.
If you do not empty it after every job and a lot of time you don't need to, just hose the debris down to the bottom of the filter and let it sit while you load everything else up to drain that hosed in water. Put it in the truck and be off and ready for your next job.
