That's my work van in those pics, just a standard length 1 ton Chevy. The 250ft.hose reel tucks in nicely behind the wastetank. This is an all new machine. Everything has been changed.. The machine (power unit) is 3" wider than the original. New exchangers, new driveshaft, optional high torque clutch, smooth flow plumbing and a wastetank that rinses out completely... I'm not trying to bring Steam Genie back per say, just the pto which is called the Steam Genie. Mark wished me well and that's good enough for me... I basically took the original design and made it into how I wanted it to be and that's what you see now. I figured I'd put it out there and just make it available again... It gives me something else to do on the side. As far as warranty is concerned there will be no issues. The unit is designed specifically for the new GM vans. If you look at the old machine and then the new you'll notice a whole different position for the driveshaft. It's closer to the blower now and several inches higher.. This new unit has a nice cradle for the shaft to rest in. The 47 blower is working out nicely. I had a Genesis 59 so I know what alot of vac power is. This is no 59 by any means but it's a nice reliable single wand unit with great power...
