Had a demanding restoration contractor, who wanted a custom flood extractor with two 3-stage vacs and a large pump-out system.
After discussing the customer's needs with John of Mytee,
he made several modifications to his Flood Pumper to meet new requirements.
We then installed a second 3-stage vac motor to accommodate 200' vac hose runs.
The customer came in to test the modified machine.
It sucked 30 gallons of water and then pumped the same 30 gallons out the 1.5" outlet hose in ....
~45 seconds.
That gives it a Recovery AND Pump-Out Rate of ~ 40 gallons per minute.
Contractor had tested 3 other flood extractors and said none of them came close to that performance level.
Larry
~45 seconds.
Larry
