The original zipper, finally got to go out and try the original on a few differnt carpets and can say the original is a bad a** built unit that works very well and recovers even better than my newer version.
Pros
Built like a tank literally
Recovers very well
You can set impact angle of the jets( new one doesn't have adjustment)
I like the clear window for the customer, as you can clearly see what coming out in the fron of unit.
I liked the foot pedal release.
I liked how sturdy it was to use.
Did I mention how dry it left the carpet with a dry pass.
Cons:
A bit on the heavy side!
I wish the window was on the front and back so I could see as I am extracting or dry passes.
The valve assembly is integrated in the handle and if your truck breaths fire it gets super hot and could burn you without the cloth gaurd.
It is defiantly harder to push not sure just because it is bigger or just because it is heavier.
Overall a super built unit that was built to last a very long time.
Pros
Recovers very well
Cons:
