Hey Larry,
Thanks for your reply I have a Mytee M5 bought in 2010 while I was living in Denver CO. Lately i have had a problem with seal inside pressure regulator/adjuster going bad. Mytee's part # RKC344 "repair kit, regulator 450psi" ordered the kit from Mytee, put it in and all was fine again. then the seal went again, i called Mytee and asked if i could just buy that seal as it was all i needed, they said they could not so had to buy hole kit again. $20 for the kit $14 to ship. Not happy, was shipped in a box way to big, could have stuck it in an envelope and sent it for way less. Have tried to find a match for that seal at various places with no luck. Any help you can offer would be great. I also have a root vac 360i with carpet brush head. and a 175 buffer with tank and carpet brush head that i break out on the real nasties. I am currently in the market for a 15 or 17inch
CRB machine. As for chems, i will have to order on line i guess as their are no supply places close to where i am in Calabash NC. I will check out your on-line store. So far $2093 for
BrushEncap Machine - 15-inch
CRB PRO 15
Counter-Rotating Brush Carpet Cleaning Machine TM4 from
Excellent supply is best i can find. other than one for $1999 form steambrite but from what i read the one from
excellent supply is a better brand worth the extra $100
Thanks again
