I have exhausted every possibility and can not figure this out......
Start my machine up and peak out the RPM's.......run 150 ft of hose and walk the end back to the truck and cap it off so I can see what kind of vacuum I am getting.....she will peg just above 16 every time.....put a wand on the end and put it on the carpet and I cant get no more then 14 out of it....normally I would get close to 16
I have checked for leaks...found 2 cracked cuff's...fixed those....adjusted my relief spring.....cleaned it lubed it...and still did not feel to warm and fuzzy about it ...so screw it... I replaced it.....Truck is running good ..machine is running and sounds good...checked everything out on the blower......I would think that if I had a problem there it would not peg and hold just above 16.......checked the waste tank lid.....checked the dump valve for leaks.........
what the hell am I missing................
