How slow?
What's the rpms?
You're right, prior to Curt Bolden inventing the Xtreme Xtractor Chuck Dewald was using the old RX-20's for extraction in his classes. It did a decent job, although I think the WET study didn't like the torque on wet backings???I have heard the old ones work pretty well as top-dry extractor due to their weight and low spin rate.
Thank you very much for the input. I appreciate your time to answer a probably stupid question. A guy near me has one cheap- not quite $50 cheap but cheap. Again thanks for you time. I will avoid.
By the way..... take a look at the hub on the starwheel... That's a metal hub! The new ones are made out of a tough plastic. This unit is not worthless by any means! These babies will still make you money!
