ACE said:
			What kind of work are you bidding on Commercial? Goverment?  All the Commercial work I have bid on has been sealed bidding.
This is for a large resturant chain I will probably be bidding on 15 or 16 different locations. I already do one store and was asked to participate in this auction. And after reading through the material lowest price does not necessarly get the contract which is three years.
Some intersting cleaning instuctions also:
The cleaning method to be used is Hot Water Extraction System.  Do not use Rotary Brush Shampoo or Bonnet/Absorbent Pad (“Spin Bonnet”) Methods.  These machines damage the carpet.
1. Detailed Process:
a. Move all tables and chairs – Do not stack chairs or put on booth bases.  Must be moved to Lobby
b. Ensure a thorough vacuuming before the detergent is applied.
c. Pre-spot area as needed
d. Apply the detergent solution to the carpet.  This will soften the soiling and hold it in suspension.  The pH of this solution should not be above 8.5 and the detergent used should be a low residue formulation.
e. Agitate the carpet and solution with a groomer or pile brush.  This will help loosen debris and tangled/crushed fibers.  This is especially needed in the high traffic areas of the restaurant.  Again, DO NOT use powered rotary brush machines.
f. Extract solution using hot water.  The water should not be over 200 degrees F and the pressure should be over 300 psi.  If a rinsing agent is used it should have a pH of 7.0 and under.  This should be done in two passes at right angles to each other.
g. In the even that a detergent residue has built-up, hot-water extraction cleaning with just water (no detergent) will be helpful.  A small percentage (approx. 2%) of mild acid, such as white vinegar, may be helpful in breaking down the alkaline detergent.  To help prevent detergent residue build-up, a plain water cleaning as described above should be performed in lieu of a detergent cleaning every 3rd or 4th cleaning.
h. Carpet should be dried by use of fans or air movers
i. Return all tables and chairs to appropriate rooms and locations
