OP machine with brush on TnG
Goomer
Frank Mendo
Any advantage to scrubbing TnG with a oscillating machine with a hard surface brush instead of a rotary 175?
Is the oscillating action more effective than just rotary revolutions in digging into grout?
Will the slower oscillation sling less slurry than the faster revolutions of a 175?
Johnny
Johnny
I use an Orbitec Brute 17" OP with John G's grout brush. Varying length bristles get into grout lines fairly well, but still use a pole brush. Made an effective sling ring from vinyl baseboard. Sometimes strap on one or two 12" sections of railroad rail for weight. Probably easier to handle on a slick floor than a 175.
Goomer
Frank Mendo
I'm assuming that some level of additional pole work will always be likely to encounter most of the time.
Any advantage that can be of benefit by mechanically scrubbing to cut down the amount of manual pole work is better.
Some of the same established arguments to support whether either motion is more effective when cleaning carpets when comparing an oscillating machine and a rotary should similarly apply here.
Is the physical contact between the bristles and the grout more effective if it is in a slower, multi-directional orbital movement, as opposed to a faster rotation in only one direction?
I would think logic would favor an orbital motion, but unless this translates into a calculable difference, it's probably not worth pursuing.
Who here has scrubbed T/G with BOTH?
rick imby
Rick
Cost factor difference is huge. Basic Ops are still around 2k and grout brush an extra $200. I have both but only floor pads, no brush for either. 175 with floor pad my choice.
I can't get past my belief that it's impossible to have useful brush contact with recessed grout lines with any planetary machine.
Reactions: Lee Stockwell
KevinL
Kevin Leach
So it's time someone made a tool to power scrub grout with a scrub brush that spins vertical.
Reactions: CanadianRuss
I can heel a 175 quickly moving more muscle into the lines than an op or crb in many cases.
Better chemicals, dwell time, and Turbo hybrid have largely eliminated machine brush work.
encapman
Rick Gelinas
I agree with Lee. Heeling a 175 machine is a monstrous way to dig into grout lines. No other method of scrubbing compares.
Here I am heeling a 175 with a Malgrit brush...
KevinL
Kevin Leach
Try doing that with appliances inches away.
rick imby
Rick
Sorry Rick---you are way off this time
Properly Heeled is sitting next to your left foot...
Not three feet in front of it.
It appears your posture is not proper either, feet together at attention...
Funny looking dog by the way..
