Will it be used with a portable or a truck mount? I have used mine with both a dual 2-stage portable, and my truckmount, and it works well with both (I have hole
glide vacuum shoes)
I have seen several claims that a rotovac 360 it uses less water than a regular wand, but my experience is the opposite. Rotovacs are good at FLUSHING the fiber, and if you match the flow to the vacuum, the dry times are not that bad (I run mine at about 300-350 psi on the TM)
I would love to see the difference from the 360 to the 360i.
