Depends... Do you do rugs or grind & polish stone? If so I'd go with the Cimex... If you just want to clean commercial carpet either will be fine. I think the Cimex is more productive but the Orbot will remove more soil... Visual apprearance will be comparable. The Orbot can be used on some residential jobs especially for pre-scrubbing prespray or padding after extraction & can be used for polishing stone with Gorilla pads or Monkey/Cheetah pads. \
I own a cimex and love it. I use to scrub in and lay down pre spray at my restaurants for hwe. I have a 100,000 sq ft commercial account I do and the cimex has played a key role in making a very competitive bid profitable
