Our Customers are our "Design Consultants"--Seal-A-Door Evolves
S
sealcanvas
"You saw, you spoke, we responded!" Dominick V Cassano and Gerry Millersuggested "something so people and pets don't walk right thru it", Mark Saiger was hoping for a spot to " attach my logo" and Heather Boggs Pinckard challenged us to "show pink!" In addition to making a minor adjustment to strengthen the attachment to the frame, we have added a "Branding Band"...helps to see it in use; good location for logo'ing or at least company name and phone number, and yes Heather....could easily be pink! Your order is the first fulfilled Mark...it's in route! Looking forward to your pics and comments!
Construction is, again, of the highest quality standard. Durable frame and vinyl coated poly that is industry named "Super Screen". Price: "Standard": $163.95; "Combo": $164.95 and "Jumbo": $184.95. The only difference between the "Standard" and the "Combo" is the frame compression. The "Standard" will only fit into typical residential doorway opening using approx. 10 lbs. of pressure. The "Combo" will fit typical commercial doorway opening using approximately 10 lbs. of pressure and will compress down to fit residential with approx. 25 lbs of exertion. The fabric pattern and size is identical for both units.
This "new version of Seal-A-Door won't be for everyone, but for those that feel a screened version would be "perfect"....here you are! We are excited for you feedback and opinions!
