Ozone Odor
Shane T
Waukesha, WI
Shane Tiegs
Potential customer called wanting me to clean a mattress. While having some outside work done on his house they found some bad insulation and siding in the area of the bedroom, so after it was all removed he rented an ozone unit and ran it in the bedroom. Now a week later and after ventilating a lot he says the room still smells of ozone. He has also removed the mattress and carpeting. Any suggestions?
LOL
Wow he must have pounded it with Ozone.
Ozone is a great deodorizer but doesn't penetrate very well. This dude must have really hit it hard.
How to get rid of it? Air exchange is the fastest, easiest and cheapest. Just guessing but I'm beting he just opened windows and ran a box fan. Good idea had the Ozone generator simply run a few hours.
He is going to have to get more aggressive with air movent. Particularly in areas where there is little air movement to begin with.
Ozone gas is unstable and will revert back to O2 if allowed to do so. Axial fans, Airpath or plain airmovers will all speed the exchange.
Activated charcoal would also work but is more passive and would still require air movement.
An airscubber with an Odorklenz cartridge would also work well. Get the one specific for gasses.
Good luck!
Heart of Dixie
One other thing: Ozone is highly reactive and can create strong odors with some things. Sniff around and see if any object (often plastic) is giving off a pungent odor. Remove it and see if it helps.
GeneMiller
Boca Raton
gene miller
no way ozone is still there. its an unstable molecule and dissipates in about 30 minutes in most cases. beside ozone is a nice clean smell.
grizzley
United States
Tim
Some folks find the odor of ozone offensive......In these instances, www.noia.org sells a product that actually neutralizes the ozone odor completely.....Its nothing but a product that you fog after the ozone treatment.......For an extra charge......but does work amazingly well...Most fogging products just mask the ozone smell and after a day you can still get hints of the odor.
Normally it does but when trapped with no air movement I've seen it last for days even weeks in clothing or other soft goods.
Its smells a bit like chlorine. Some associate that with "clean" other witb a "chemical odor".
I'd have some reservation fogging a chemical into the living space when they are already having an issue with another odor.
I'm not questioning the efficacy of the product, I just feel in an instance where there may be heightened awareness of chemicals, I don't care to introduce another one.
