Who here sells it? Can you get it in custom lengths?
about time I give it a try.
Of those that use it how do you like it and is there anyone that made the switch but went back to steel braided
I started with Parker (it was on reels the tired TM I bought) along with a whole spool Parker
Used it for a few years til the roll was gone, then went to Ineptune...I had more instant failures in that year and half I used Ineptune than I've had in
22 years of using Parker
Draw backs of Parker are;
It will never be as soft/flexible as steel braid.
Doesn't play well with small arbor and live hose reels
Doesn't hand coil worth a chit.
Jacket blisters and develops pin prick sprays nearest the TM within a month or so when running a
steady daily diet of 250 temps.
230 temps with occasional* 250+ temps and it will last virtually forever
(*"occasional" meaning 10.93% of the time on a 500 TM hour a year work schedule )
Pros;
MUCH lighter than steel braid
Not nearly as hot to touch ....you won't permanently scorch/distort poly/olie carpets like steel braid can l and does
Carries more heat to the wand
Safer, cause there's no
"instant" blowout failures
No black water issues at start up
lasts MUCH longer
Smooth jacket, so it doesn't "grab" door jambs, wall comers, carpet ...
glides smoothly
