John Olson" data-source="post: 4231715" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Something is fishy. The gauge doesn't look spun but it has been sitting outside for a long time see all the filth on the water tank. Also you don't get that amount of rust on the bottom of the frame in 858 hours but if it could be shipped id make a run at it but not at 4k unless I could hook it up and run it.
John Olson" data-source="post: 4231715" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">I dk John, new York is a whole different climate than where you are with long nasty wet winters and lots of humidity in the summer. I bet if that thing was in a pos van for a few years its possible. This may have been a weekend warrior whom it took 3 years to rack up that amount of hours or spent a lot of time in storage and that could explain the rust.Something is fishy. The gauge doesn't look spun but it has been sitting outside for a long time see all the filth on the water tank. Also you don't get that amount of rust on the bottom of the frame in 858 hours but if it could be shipped id make a run at it but not at 4k unless I could hook it up and run it.
