Pembertons Pulling out the GUNS!!! 6 TM's
Scott S.
PA
Scott
So yeah, Jim Just informed me that on October 23rd @ 8am there will be a Sapphire van here with an 870 and a 370 in it, as well as the three pro1200se's, and a RAGE.
Pro1200se in a standard length van with a water pond, and a apo system.
Pro1200se in an extended length van, with a water pond and a apo system.
Pro1200se in Sapphires extended length van, with water pond, shelving, and toys to play with.
Rage in a standard length ford van with a hydrowell II, water transfer pump, extended chemical shelf for the hydrowell.
a 870, and a 370 like the one Mikey just bought.
Its going to be quite a showing!!! You will also be able to demo the machines and see what a glided pimped out wand feels like, and how it will save you alot of strain on your back.
If you want to go call Pembertons to register, 1-800-342-2297
My wife and I will be there if you want to see faces to the names. I'll even show you how to save you some wear and tear on your water pump.
Scott S.
PA
Scott
Is that the most installed Pro1200se's in one spot ever?
oh, there might also be a nice used thermal wave there also to check out.
