Completed Pet Odor and Smelly Season is coming. Saiger's Sauce has you covered!
Completed Auction
This Auction includes:
  • One 4 x 1 Gallon Case Saiger's P-Lime-Zyme Pet Treatment Retail $90.44
  • One 4 x 1 Gallon Case Saiger's P-Zyme Eucalyptus Mint Pet Treatment Retail $90.44
  • One 4 x 1 Gallon Case Saiger's OdorOxy with Mango Burst Cide Retail $119.95
Saiger’s P-Lime-Zyme & Saiger’s P-Zyme with Eucalyptus Mint
Saiger's P-Lime-Zyme & P-Zyme Eucalyptus Mint are ready-to-use active solutions with a special blend of odor counteractants to immediately knock down and keep odors suppressed while bacterial enzymes go to work. Pet Stain & odor destroyer contains bacteria that produce multiple enzymes to digest odors at the source quickly and effectively. It will eliminate odors caused urine, feces, grass, mold, mildew, organic rot, vomit, smoke, skunk, and more.
Directions:
  • Apply liberally at 4 to 1 ratio to the affected carpet even forcing into severe areas into the padding. You may also apply at full strength.
  • Apply to all surfaces using Warm water vs Hot water (120- 160 degrees) DO NOT APPLY DETERGENT AT SAME TIME.
  • Shut off your chemical injection on Truckmount during application
  • Allow to dwell 30 minutes.
  • Extraction after dwell time can use detergent and even apply Saiger’s Sauce 1 or other Pre-Spray over top if more severely soiled.
Benefits:
  • P-Lime-Zyme & P-Zyme attacks the source of the foul odor and eliminates the organic residue that causes it.
  • Effective on a wide variety of organic odor problems.
  • P-Lime-Zyme harness the power of natural enzyme formed by good bacteria, so it is completely safe for use around your pets and children.
  • Suggested Product Use:
  • Pet accidents on carpet, floors, furniture, and clothing.
  • Spray in litter boxes, pet beds, and animal cages to deodorize.
  • Spray on mattress and bedding after accidental bed wetting.
  • Laundry spotter and presoak - will work on all organic stains. Apply directly onto stain and allow enzymes to consume the organic matter. For a laundry presoak mix 8 oz per gallon and allow laundry to soak for 45-90 minutes and then wash.
  • Can be sprayed at the base of toilets for deodorization.
  • Pour down sinks and drains to maintain your sewer lines or septic tank. Add 2-3 oz twice weekly to keep drain pipes flowing freely.
  • Spray in garbage cans to help deodorize.
  • Always test in an obscure area prior to use when treating silk or wool fibers. Avoid all contact with open wounds. Keep the container closed when not using. Store out of direct sunlight. Do not take internally. Note: Do not subject to extremely hot water.
OdorOxy Urine Odor & Stain Destroyer
Odor Elimination with the Power of Peroxide and a True Odor Destroyer! ODOR OXY is a unique high-powered Peroxide formula with a true Odor Destroyer! Not a masking agent, but a product meant to go after the urine and odor-causing organic stains! With the power of Peroxide and our unique Odor Destroyer. Designed for those cleaners who do not have the time for enzyme activation and need quick fast results!
Odor & Stain elimination oxidizers that will remove organic stains including pet urine, blood, coffee, vomit, and more. A unique formula to eliminate unpleasant stains and odors in carpet, upholstery and other fabrics.
Avoid using on Wool and Silk materials, and be cautious with natural fibers.
How to Videos using both products:
View: https://youtu.be/pPvkycfL8rI
View: https://youtu.be/sLNJbt6RXx0
Total Retail Value$300.83
Free shipping to the lower 48 states
Starting bid $200
Minimum bid increment $2
Auction ends Thursday June 8th at 9PM EST/6PM PST
Latest Auctions
