PIC OF GREEN HORN WAND
S
Sticky
the sun in the pic most be glowing off the owners face....GH is the best!
K
KOOSER55
whats the benefit for a gh wand over the standard hydramater wand with 2 jets?
Eric Valentine
The GreenHorn has 5 evenly spaced jets that are closer to the carpet. This will get more heat to the fiber, where it can do some good, instead of heating the air. The GreenHorn's jets are also angled to just skim the glide surface, allowing you to turn the pressure up if needed, and not spraying the solution straight into the backing. You also will have better airflow with a true 2" tubed wand, versus 1.75" with the standard 2 jet wand.
