PIG or POG
Shorty
Cairns
Shorty Glanville
PIG is for Paint, Ink & Grease.
POG is for Paint, Oil & Grease.
I believe that PIG is replacing POG, which is being phased out.
Hope this helps.
Ooroo :roll:
SRI Cleaning
West Chester, PA
Anthony Firmani
So will the pig still remove oil and the pog still remove ink or are there different components between the two? Basically I'm wondering if they are the same product with different names or are they completely different products.
Dallas, Texas USA
SRI;
POG is still the name customers ask for.
A good POG will remove Ink.
The real question is removal of dried enamel paint.
There are many attempts in the marketplace.
Larry
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
As Larry says, many manufacturers attempt to make a POG or PIG product. They both remove the same types of stains.
Both POG and PIG are NVDS (Non-Volatile Dry Solvents) but may be a different combination of these solvents from brand to brand. They have to be rinsed with a volatile solvent to prevent residues that can resoil.
You may also want to look at a new product that uses water miscible solvents. Basically that means it will disolve in or mix with water and rinse out easier. This is calle OINK for Oil and ink remover.
Scott Warrington
