Feb 12, 2007 #1 J JohnnyV Member Joined Oct 7, 2006 Messages 322 Anyone ever changed the wheel set up on a Rotary and put bigger Pneumatic tires on one? I'd like to put bigger tires on mine so it would be easier to move and easier on stairs. Thanks JohnnyV
Feb 12, 2007 #2 C Carpet Dude Guest John, unless you have retractable wheels you may run into a problem with the bigger wheels rubbing on the apron. The wheels on the older rotaries are about 4".....I have a newer 17" rotary with 6" wheels. they work just fine up and down stairs.
