the green striped scrub bonnets don't work so well on a shake 'N shine machine, Curt
here's why I think that is....
the two pieces of material are only stitched together around the perimeter .
The top part (on the pad holder) holds and shakes plenty fine, but it slips/slides on top of the mated piece that's on the carpet ...it doesn't transfer the orbits to carpet
You need pads/bonnets that are stitched together length wise .
we've used VCT pads under our OP (a John G Conqueror)
The motor is more than strong enough to handle them with no bog
Matter of fact, the 100% cotton pads put more strain on the motor and have more "grab" than VCT pads .
Red pads are the most aggressive we've used with ours.
they're a breeze to run compared to cotton pads.
OP will "pill" a VCT pad ("pill" as in like some poly upl fabric gets these little "pills balls" of twisted fabric with wear)
But it will scrub fine... not as good, nor as fast as under a rotary IMO, but if room for only one machine in the van, the shake 'n shine will get it done
