brendan
hey there,,,does anyone use a seperate chemical jug on there tm and use there tm as a inline pre spray with a sprayer on the solution hose and using your chemical primer to apply pre spray
brendan said:hey there,,,does anyone use a seperate chemical jug on there tm and use there tm as a inline pre spray with a sprayer on the solution hose and using your chemical primer to apply pre spray
brendan said:hey larry,,,just saying, even with a portable you could put pre spray in portey and pre spray with wand and go from there,,,trying to help new comers,,help lads starting in this pro
Getting prespray into a 150 foot water line would involve purging a few gallons of rinse solution and then you would need to purge that for the rinse. Also you really soak a carpet with way too much solution because at 400-500 psi a wand REALLY blasts away (I've done this). It's not bad in a pinch or on a large commercial area where you want to put ten gallons down fast, but not practical for everyday. As said, use a HF.meAt said:[the biggest draw back i see is having to walk out the van to turn on and off the soap
brendan said:gobble gobble
