gimmeagig
Hi,
I cleaned a house two days ago. 20 year old beige nylon with many brown stains and also some straight brown lines about 4" wide 6 to 10 feet long like they were drawn on, strange. I cleaned it with Attack prespray and Liquid CBS (Esteam) rinse ( high PH emulsifier rinse 9ph ) and it came out looking great.
Yesterday the customer called me to let me know that practically everything had come back including some new brown stains that weren't there before. Also there was a really ugly smell in the house that wasn't there before.
Today I re cleaned the whole house again with Attack but only presprayed the surface lightly. That took out the browning. This time I rinsed with Pro's Choice Last Step ( low PH anti wicking rinse) I reduced the pressure to 280 psi and again tried not to get deep. Lots of drying passes and put my blowers on immediately.
Seemed to work except right in front of where i placed the dryers the carpet turned brown within 20 minutes. How frustrating, why did it do that? I don't understand.
I did spray the browned areas with stain magic and the browning faded away almost immediately.
Tomorrow I'll go back to pick up my dryers and I'm hoping that there is very little browning.
I have a couple of questions.
#1: Did I do everything correctly or is there something i should have done differently?
#2: If the browning does come back in larger areas, what is the best spray to use?
I assume it should be some type of coffee/tannin oxidizer spray. I suppose I could just spray everything with Stain Magic because I know it works but it might be too harsh? Is there a less expensive spray that I might be able to get in a gallon jug and pumpspray it on? Preferrably something i don't need to extract.
