I have the Blueline external APO. When the power is on it will pump for about 3 seconds, then shut off for about 15, then repeat this over and over.
I took the top off and cleaned out the 4 spring/check valves which were full of lint and hair. It still does it though. Is there somewhere else that is clogged that I need to be checking?
By the way, this all started happening the day I got talked into ditching the pool filter!!!!!
