The Cleaning Artist
- Joined
- Oct 7, 2006
- Messages
- 475
My first impressions are not good of this wand. It has the same flaws as the smaller 4 jet 11" version, STREAKS! Yes that's right and too bad for me to use it. A 1.5" streak right down the middle between the two center jets as they are further apart than the rest. With it pimped and glided the water flow is not nearly as much as my 12" 2 jetter and the cleaning is SLOWER! Looks as if I'll haf to FIX it to make it usable. What I do like is, it's light, maneuvers easily. and gets under low furniture. My truck runs too hot(280+) when cleaning with this wand @ 500 psi as jetted. Turned it up to 600 and it was still bypassing alot. Oh and the jets with check valves will piss all over for 15 or so seconds after the trigger is released @ 280 and so will the stainless soft touch trigger valve. I'm going to make some changes and see if I can make it usable. I really like the feel of this wand and if it pans out will purchase another one. Looks like it will get tuned the ARTIST'S way!
