Prochem legend pressure problem
Jim1147
Nj
Jim
I have a prochem legend, been having some issues with fluctuation in pressure at wand. Cleaned the screen and orafice and it seemed to help. Yesterday I Descaled machine and now when I run at full throttle and open valve on solution line I get one surge of water and machine cuts off. Any help/ advice greatly appreciated
Sounds like you have some serious scale issues. Have you pulled the solution outlet QD and tried running it?
Sounds like the descaling created a blockage somewhere or in several places in the solution system. If you pull the hose on the pressure side of the pump, do you have flow?
Jim1147
Nj
Jim
Disconnected hoses and don't see any scale
Build up . Nothing in any screens or check valves. Machine just cutting off no pressure. Do you think it could be low pressure switch.
Jim1147
Nj
Jim
Minimal
If I'm hooked up to wand 10 seconds it shuts down and pressure is low
With an open valve on solution line it shuts down almost instantly
I'll try bypassing in the morning
Thanks for your help
if "shut down" means you lose pressure and little to no water flowing, and not the pump clutch disengaging or engine shut down...
...did you find where it's sucking air upstream of pump yet?
.L.T.A.
