Newman
I bought my White Magic 1200 used in 2007. It is in a 1 ton Chevy van. The RPM was set at 1200 (from the factory?) with the machine running / no load. I checked the manual, the stated RPM range is 1200 to 1500. I thought OK, running at the lower end of the scale will wear the machine less and went on to the next thing.
3 years later I had to pull the throttle cables to service the engine. I reassembled the engine and set it to run at 1500 RPM, no load, with the PTO engaged.
Man that woke up this old White Magic unit! Should I keep it @ 1500? What RPM's are y'all runnin at?
