Pump For Multi-Sprayer
bensurdi
Snohomish,WA
Benjamin Surdi
Hey guys, it seems like these pumps keep going bad on me. Anyway... Wondering where you guys get your pumps to repair these multi-sprayer systems. It looks like Aquatec 5800 is the pump type. But was curious if anyone has put a better pump in it that lasts longer?
Reactions: Askal
Johnny
La-Z-Boy
Johnny
For the 12VDC battery model, upgrade to a Shurflo 8009-543-236, 60 psi, 1.8 gpm. More powerful and has a built-in pressure switch, so pump runs only when you trigger the valve. I've been through a few of them over many years. Rebuildable. Less than $100 from Northern Tool.
Ps. You'll need a much bigger jet on your wand to handle the increased flow. Can't tell you what's on mine cuz the numbers are worn off, but it's a big ole hole.
Reactions: Jimmy L
8004 jet
