pump issues
what are some signs that your pump is going out or needs to be replaced. experiencing some delayed pressure if i dry pass for short amount of time and i trigger the wand little or no pressure comes at that point, its after a few seconds that i will regain pressure again after i have been holding the trigger. once i regain pressure at the wand and continue to trigger the wand on the back pass and continue pressure will hold up. its a 3cat pump.
ascrubabove
Holly Ridge, NC
if the pump sucks any air in you will get a pulsation in the solution line and it makes your wand feel like its vibrating, the pump sucking air, or running dry is a bad thing, check the strainer and float in your water box!
