pump question
does a 2.1 gpm pump
that delivers 60 psi
have enough behind it to push solution threw a 1/4 inch line about 185 ft long..................
If not.........what gpm would I need to look for.......
this would be a 12 volt demand pump........
this is just for applying pre-spray.............only
still think 125 or would 60 be ok
will I have 60 by the time it gets to the end or will I have a dramatic pressure drop
Last time I presprayed with and old tired 100 psi 12 gal porty, I had 100' of line out and a hydroforce type spray gun with a 6503 tip, I had plenty of pressure and volume, I think you will be okay.
I don't know about a higher flow rate like an 06 tip though.
