LOOKS GREAT...however
spray on solvents will get on the souls of your shoes and when you step on the bedliner will SOAK into the shoes and thus TRACK back on the carpet....
Most vans came wit a rubber liner.....jus put it back in after the rino line................
the bed liner i sprayed on was water based not solvent based. takes 2 days to cure.. i only did this so that i could keep the floor from rusting. i plan to put a rubber liner in it. this was only a precautionary measure. plus it looks great.
