Finished with all service work yesterday with exception of cat pump. I apparently am out of oil for this change and can't find my notes after the move. Did the search function but couldn't find specific info. Cat manual says 17 oz. of ISO 68 hydrolic synthetic and I have read you could just use 10w30 or equivalent. I want to use synthetic any suggestions of what you use.
Also, notice at 1500 hrs I should be looking at a seal change, I'm at 1944. Can one just call cat pumps to order the seals or does anyone have a favorite place they order. Should I also repalce valves while in there (recommended 3000hrs) or just do the seals. I have not experienced any problems with pump and since I have owned have only ran dry one time for (as fast as it took me to RUN to turn off) 15 seconds.
