REAL WORLD HEAT AT THE WAND!
T
The Preacher
outside air temp - 71
incoming water temp - 68
220k BTU propane heater dial set - 245
012 quad jetted wand open to air, candy thermometer with 302 degree rating - 180 degrees at the jet (measured each jet)
didn't measure my 08 jetted PMF since my coupler started coming apart and machine vibration was too bad to continue :(
T
The Preacher
TEST 2
55 degrees outside air temp
heater set at 245 degrees
04 jets on dual jet wand - 162 degrees at glide
03 jets on quad jet 174
turned heater down to 175
04 jets - 138
03 jets - 145
so i surmise that more flow with smaller jets will give me a little more heat at the carpet, yore results may vary depending if yore TM is a POS!!!LOL
H
harryhides
How do you get less flow out of larger jets ?
Of course with you anything is possible but 4 04's = 16
vs
4 03's = 12
Did you measure the flow with each set up ?
Latest Auctions
