recovery tank filter for STM GENIE
glenboy
MACOMB MI
GLEN
I'm looking for bawb....my recovery tank filter has stopped letting air flow thru....I believe its a 2 5/8 female stainless about 10 1/2 " long......WHERE CAN I FIND THEM??? Locally or However
GLEN
Doug Cox
Delavan, WI
Doug Cox
You can also send Shawn Forsythe an email since he was a "Big Wig" at Steam Genie.
bob vawter
Grassy Knoller
La La Land
bob vawter
i sent my last two to Chris Lee...
lil' shit still owes me two small boxes of .22........:angry:
dgardner
Phoenix, AZ
Dan Gardner
Bawb, I'm not familiar with the SG - are the filters just FPT pipe thread inlet like the ones Cobbs sells?
This one is 2-1/2 pipe thread X 12" long - is that close?
bob vawter
Grassy Knoller
La La Land
bob vawter
no dan...there are no threads at all..jus slip on....the pipe size is 2 7/8" OD so the fiter is SLIGHTLY larger than that...
all stainless...no plastic.....
damed if if i can remenber where to get one...'pensive...'bout $100....i think!
Modernistic MAY have a few used ones talk to Tom
Reactions: dgardner
glenboy
MACOMB MI
GLEN
Just spoke too tom.....he is on the prowl for one.....thank you bawb! I believe this is causing my vac flow to just choke.....the filter looks clean...but wont allow air too pass thru...reducing my extraction big time
glenboy
MACOMB MI
GLEN
Has anyone ever had this happen.???..I believe this is why I am roasting belts and have very minimal extraction...
dgardner
Phoenix, AZ
Dan Gardner
A picture would be interesting - I assume you've tried to clean it? Wire brush? Soak in descaler?
glenboy
MACOMB MI
GLEN
Its never filled with fuzz....you can't even tell its restricted...so I threw my vac hose into the end od it today...and my vac guage went up....normal...but the sound was unuasual..yes I soaked in descaler overnight...wire brushed it and nothing came of it...solution was clean too...so I ran the machine today with no filter in recovery tank...ran like mad...huge vac...
bob vawter
Grassy Knoller
La La Land
bob vawter
NO WIRE BRUSHES!!!!!
Pull it off and spray water from THE INSIDE
Once you wire brush it.....
It is pretty much toast.....
Reactions: dgardner
glenboy
MACOMB MI
GLEN
Bob its toast...why? I have no clue how this has become so restricted...from within....THERE is no visible obstruction....
dgardner
Phoenix, AZ
Dan Gardner
I'm just thinking out loud here - maybe Bawb will chime in - but if the filter is really old could the structure of it be weakened to the point that when installed and under vacuum it is collapsing inward and restricting airflow? When you shut the machine down and look it might not be apparent. Grasping at straws here....
glenboy
MACOMB MI
GLEN
Stopped into applied technology over in Sterling Heights Mi.. dropped my old filter off so they could search out a new one...left there went to see Tom at Modernistic and they had a filter that fits loosely but does the job...looks just like the pic posted above
Reactions: Lee Stockwell
bob vawter
Grassy Knoller
La La Land
bob vawter
too bad Glen....i sent TWO filters down to TN....three months ago
SUPPOSE to trade for some .22 ammo........
never saw the ammo!:(
glenboy
MACOMB MI
GLEN
I just opened my old filter and the screen mesh part has a layer of dried silt on it...from the inside....pics later...
bob vawter
Grassy Knoller
La La Land
bob vawter
ya they don last forever....i worked one prolly close to eighteen years tho...
always rinse from inside out.......
Dallas, Texas USA
We have never used a 100 mesh screen in our vac filters . . .
Clogs too easily . . .
We currently use a 30 mesh for better flow characteristics . . .
They don't get clogged near as easily . . .
Also, I think a 50 series filter should be a 2" FPT . . .
glenboy
MACOMB MI
GLEN
Ok the filter I now have is sapphire filter...im not sure of the micron size?
Although I have been using it for just over a month and already noticed reduction in airflow..vac..I believe this was stated prior on here...Aklthough with a new SS filter, and a new PC quad jet wand...my cleanings have improved massively...and the drytimes haven't gone unnoticed by me or my customers....I am so freakin happy...:rockon::rockon:
Reactions: dgardner
