ACE said:
To be honest, I have never used a rotary extraction tool. The operators I know that RX-20 everything all seem to have a loyal customer base and they seem to be able to justify a good rate, so maybe they are on to something. If nothing else, it differentiates you from the other guys.
I have a few questions about rotary cleaning in general:
What kinds of production rate to you get compared to the wand?
What style of carpet dose it not work well for?
If I buy a rotary it would be a used RX 20 or a new 360i. How does the RX 20 compare to the 360i?
I am and always will be a avid rotary cleaner.......and because of the difference a good rotary cleaning will provide....you will gain a stronger more loyal client base.....
your production rates in a normal house setting with a rotary are a bit slower then when using a wand.....but....they are faster when doing a large empty or a big commercial job.....
I have used a rotary on every type of carpet out there with no problems what so ever....but...if you are using a RX..the set up is important........and the common since thing has to really kick in.....you have to watch for bad seams and holes in the carpet.....
both machines are good...both have there advantages and dis advantages....but after using a RX for ever...I am liking the 360i more and more....the recovery on this thing is amazing...very light weight....and so far seems to be a work horse....I have rode it hard and put it away wet these last few weeks and it is holding up pretty good.....not the most user friendly rotary out there....adjusting the tilt is stupid the way it was designed....the machine has no place to wrap and store the 800 foot cord that it comes with ...and the way you have to connect and dis-connect the vacuum line is apparent no one put to much thought process into....but aside from the tilt...the others I will fix myself to make it a bit better to use....
the RX is heavy...but it is a lot more user friendly....when you use a rotary all day this is important....one thing that I do like better about the RX is that you can change it to how you like it....
glides..jets ...etc..etc...the 360i...you get what you get and that is it....
The RX production rate is much better then the 360i........
