Rotovac joins the Portable Shoot Out @MFE!
Dwell Pro 1 and 2
EDIC Galaxy 2000 (and Bravo Spotter)
Sapphire's new rig
Interlink's monster Nautilus
and the Rotovac Ranger 1200
The Ultimate High Powered Portable Extractor
Double Your Cleaning Range
The Ranger is approximately the same overall size as a standard 12 gallon portable extractor. The BIG difference is its extra large 24 gallon clean water holding tank with a removable "Extractor Pod" (Pump Out Device). This enables the operator to clean more than twice as long as a standard extractor without stopping to refill and empty. Or, use the auto-fill to clean without stopping to fill. The Ranger's unique modular design allows the 40lb Extractor Pod to be easily removed from the 54lb lower 24 gallon holding tank for easy loading and unloading from vehicle. The Extractor Pod can also be used without the 24 gallon holding tank for direct faucet hook up non-stop cleaning mode.
  • Huge 24 gallon holding tank with auto-fill
  • Auto pump out
  • Dual high velocity 2-stage vac
    motors with 200 CFM
  • 1,200 PSI adjustable Pump
  • Converts to Compact CFX
    (Click here to see CFX)
  • Eliminates The Bucket Brigade
Come test all these units with your choice of wands, REs and the Zipper!
Art Kelley
Clawson,mi
That's an odd choice for them to bring; the dual two stage model is a weak machine and will soak the carpets when used with their 360i. The dual three stage CFX is a powerful performer, and the 15 gallon model eliminates all the problems they have with the smaller 5 gallon CFX.
