RPM
When your machine is running ,not under load . What RPM is ? Under load what RPM is it? What HG doe the machine go to?
25hp Kohler
45 blower
relief set to hold 14hg
2200 wt generator
No load and no heater on (which puts a load on the generator), I'll drop a couple hundred RPM under full load.
Note; I'm not positive of that though, cause I throttle up to 3200-3250 with the vac hose hooked to the vac port, but wand not on the carpet yet.
Under 14hg load and when the heater kicks in, it'll drop 100 rpm or so
2200 RPM
10 HG with 2 inch free flowing about 125-150 feet out
13-14 HG with a wand on the ground cleaning
18 HG with it capped off at the end of the 7 footer
and it runs down to 2000 RPM.
7 HG with it free flowing on the end of the 7 footer
Chad has the answers I think Nick is asking for:
1. RPM - No Load
2. Vac Level @ TM with XX ft. hose only connected
(Hose Loss @ max CFM)
3. Maximum Vac Level (sealed) & RPM Full Load
Mikey Board Supporting Member
