Walt
- Joined
- Aug 1, 2007
- Messages
- 1,016
From what I can tell the diffence is in the type and number of jets. And the slots are smaller on the HE.
Does this make much of a difference?
danielc said:I have used both. The half slots are not as aggressive and do quite well on all carpet surfaces. The full slots will need glides or you might damage the carpet. The cone jets can be replaced with 8002 jets for 6 flow. I have (5) 80015 jets for 7.5 flow.
If I had to choose one setup, it would be the half slot and three 8002 jets. You will be good to go for most situations.
I wanted the higher flushing and faster cleaning so I went with 5 spray jets and 5 full vacuum slots with slot glides. The RX is not a fast dry tool. This needs to be explained to the customer. If they want faster drying, a regular glided wand can dry the carpet out after rotary cleaning of course for a higher fee.
royalkid said:danielc said:I have used both. The half slots are not as aggressive and do quite well on all carpet surfaces. The full slots will need glides or you might damage the carpet. The cone jets can be replaced with 8002 jets for 6 flow. I have (5) 80015 jets for 7.5 flow.
I disagree. A wand will dry carpet faster?? Let's see, 5 slots on a RX with 120 rpms = 600 dry passes per minute VS. a wand...what, maybe 40 dry strokes per minute (and that seems fast)...and how long before a hack starts half-assin' dry strokes w/ the wand? I can do dry passes with the RX all day. RX better rinse, better extraction...hands down (IMO).
